bill gurreri
where can i get copper head gaskets. and does anyone carry heavier duty head bolts and studs thyan the crap that comes on these grubees....
 ree day turns to rain so i'll keeop ya posted....also my loal hardware store has the copper sheets but i wonder how it would hold up,,,, any input...
ree day turns to rain so i'll keeop ya posted....also my loal hardware store has the copper sheets but i wonder how it would hold up,,,, any input...Use something like Permatex Copper Hi-Temp Spray-a-Gasket and a torque wrench. You might also need to tap the head stud holes, too. The Chinese have a tendency to not fully tap the holes. That goes for the mounting and intake and exhaust studs too. That has been the problem with many heads that haven't sealed right. The stud bottoms out too soon and the the acorn nut gets to the bottom of it's thread and you get false torque readings. M6 1.00 torque to 10 lbs and an M8 1.00 or 1.25 to 15lbs. Use some kind of a torque pattern like an "X" or "Z" , don't just go in a circle around the head. That causes an uneven force on the head and can lead to failure.
Dave C is correct about the acorn nuts bottoming. I've seen too many for it to be a random issue. Replace them with shouldered hex nuts. Proper torque and a flat sealing surface is essential for a good head gasket seal. Good luck.
If that was the case, then there would be no issue of false torque reading due to the stud bottoming out in the dome.Usually when you 'bottom out' those cheap acorn nuts, the dome will just pop off.
