BikeBerry gas tank mount 'upgrade'. Wish I hadn't
jeffpas
This video convinced me take my gas tank off after everything was on and solid just fine, and redo it with four brackets instead of two. The sales pitch presented was convincing: those weak little welded bolts, they say, eventually break from the vibrations of running the bike and the stress of being pulled from below, with the traditional 1 bracket mount.
Instead, use 2 brackets on each side. Screw nuts all the way to the tank, then upper bracket, lower under, and bolt. The tank then sits on top with no pressure, and viola.
Never mind that I had already used threadlock on my tank so it was a lot harder to get it off than I anticipated. The washers had to be pried off basically. Then even after cleaning the threads, I couldn't get the first nuts half way up those weak little welded bolts, due to the paint already on them, and threadlock, and on. All this time I'm thinking I'm putting all this pressure on those welds, which may make them leak all the SOONER.
By the time I was half way I chickened out, I thought it was just too much torque and would rip those bolts.
If I try cleaning them with a wire brush like in the video, I'm stressing them and they may even become loose if I keep at it. Thats not good.
If I try some kind of acetone or paint remover, that's only going to make those bolts more likely to leak too.
Its just a real PITA. So my question is.... is it really necessary?
How often do these gas tanks leak screwed on just the traditional way. I can't mount them the way this video recommends :/
For years, I've been using 3M two sided tape to help mount the tanks.
I put a long strip under the tank where the frame tube will be, & I also put some on the mounting brackets... This keeps the tank secure enough so that you don't have to over torque the hardware to keep the tank from moving.
I also use purple Loctite on the threads... (yes there is a huge difference in the different colors & numbers of Loctite)!!!
Purple is for small threads & is removable.
Assuming then you use the double sided tape, go ahead with one bracket not overtightened and they DONT end up leaking?
Again I'd love to keep trying the double bracket thing but its looking like thats going to rip the bolts loose at their welds, and it will leak at installation!
good grief
I've never had any problems with leaks around the gas tank studs.
I'll get some pictures of what I'm talking about & post them here.
Here's the pics of how I use the two sided tape on the gas tanks...
I had to remove those nuts & washers you see on the tank before I installed it.
They were installed by the customer before he brought the bike to me to fix...
(he was probably watching the same bike berry video you were)!! laff
I've used this on these on my Schwinn Stingray OCC, it helps with the vibration :). All tanks come with a little red or black rubber washer to prevent leaks. If you don't have one use Permatex Gray Fuel Resistant. Used that as a sealant on one and never had an issue with leaks.I have access to a welder. But instead Gorilla taped the tank because it's too wide lol. It will require longer studs lol.
My preference is Velcro on the bar of the bike and the bottom of the tank. Help's to keep it from moving around and no need to overtighten the nuts to cause a leak. Just my two cents.
Sorry to bring back an old thread but I have been tweaking and riding 8 motorised mountain bikes since 2013 - and after 2 of them developed leaks around the welded studs I have done exactly what the OP found in the video to mount all my fuel tanks!
-Clean the paint off the threads first with an M5 thread cleaning die or standard thread cutting die!
-Screw a nut all the way on to each stud then use a bracket both on top and underside of the frame (the top two brackets go under the brake/gear cables if present)
-use just enough washers or 10mm nuts as shims between the two brackets so that nylock nuts can be tightened all the way tight on the bottom of the threads to clamp the frame between without bending the brackets - the double sided tape is a great idea, I have glued inner tube rubber there to make sure the tank doesn't rotate around the frame too easily!
When done like this the welded joins between the threads and the tank are not being constantly pulled on like they are in the traditional setup which if ridden enough WILL result in leaking fuel - it can take many years before it happens though,
John
John
It's always satisfying when you find a solution to a problem.
