Bike storage
Discussion in 'Motorized Bicycle General Discussion' started by thxcuz, Feb 9, 2014.
  1. thxcuz
    thxcuz Member
    Jul 26, 2012
    288
    I'm kicking around the idea of building a 4 stroke motorized bicycle
    My issue is I have nowhere to put it. My garage is full of junk like my car and my bicycle and my kids bicycles and a lawn mower and other things that are necessary to my life.
    Is it possible to store it year round outside? I live in St. Louis where we get every kind of weather (sometimes in the same day) it's below zero in the winter and over 100 in the summer.
    I'd put a tarp over it if it will help.
  2. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    I got 2 bikes outside now chained to a fence with a tarp over them. Same thing, no room in garage. Both are for sale.
    Come spring time I'll fire 'em up and let you know.
  3. d_gizzle
    d_gizzle New Member
    May 29, 2012
    1,103
    You got a sell thread mikeb? I like to window shop......
  4. maniac57
    Oct 8, 2011
    4,486
    Cover it well and the temps won't hurt it. If you don't plan to ride for a month or so, drain ALL the fuel (including the float bowl) and squirt some oil in the spark plug hole before storage.
    You can also use a gas stabilizer like Sta-Bil for long term protection from gas going bad.
  5. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    If you tarp the bike thru the winter, it would probably be a good idea to remove the tires and tubes for a few hours in the spring and let the condensed moisture out.
  6. 2door
    2door Moderator
    Staff Member
    16,301
    26
    I don't know how it woud work with a bike engine. Same principle so it shouldn't be much different. We used to use automatic transmission fluid to 'pickle' 2 and 4 stroke model airplane engines for long term storage. It kept the engine from gumming up due to coagulation of oil and protected the aluminum parts. Pour a little down the spark plug hole and down the carburetor, rotate the crankshaft a few times then forget about it. Always worked for me.
  7. Russell
    Russell Active Member
    Apr 19, 2009
    1,199
    16
    Wish I had seen this thread befor winter started.
  8. xseler
    xseler Well-Known Member
    Apr 14, 2013
    2,762
    52
    I use a product called 'fogging oil' from NAPA. It's an aerosol oil that you spray in the sparkplug hole.......used it for years and it works great!
  9. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,082
    45
    If you use plastic tarps keep them up off the bike, sun beat down and they sweat and let air get under to help. Not so much winter but summer. Put down some palets or something for it to sit on and make a tarp lean to would be better.........Curt
  10. maniac57
    Oct 8, 2011
    4,486
    I've been told the best oil to use is Marvel Mystery Oil by one of my most trusted mototeachers. He also said it was the inspiration for fogging oil.
    But then again, he also said Ford was a good car brand, so I take everything he's said since then with a grain of salt.....
    Seriously fogging oil works great since it's easier to get all through the engine by simply spraying while turning it over.
    Using regular oil is messier.
  11. bairdco
    Aug 18, 2009
    6,350
    25
    Mount a snowblower engine on it and you can use it all winter...
