Hello again,
Second build and twice as many problems as the first..
I bought a used engine from a guy i was buying a bike from. I have no clue what the displacement is. It is a flat head 2-stroke. I will post pics soon.
Anyway, I installed it and it kinda started, and I finally messed around with it enough to get it running. It ran and started easily, but got a top speed of only about 15mph. I started messing with it and one day when i went to start it up it didn't work. I could get it started by pedaling very hard, but it would just die out.
Right now i can get it started if i put it at 3/4 choke, and it will run at a low speed and then die. Any other choke won't work for starting or running. I realized the throttle didn't go all the way down in the slide. I fixed that. But still no success. It gets fuel flow to the fuel line but the line is a little lose on it fitting. But it still doesn't seem to leak. I just checked for an air leak with WD40 but there didn't seem to be a problem. I think it is still an air problem. (Too much air?) I haven't opened the carb completely cause i don't even know what to look for if I do.
Any help would be awesome. I want to get it running this weekend if at all possible.
Edit: Also forgot to add that I checked for spark and it was not strong so I just replaced the plug and wire. Better spark now. And the clutch seems to be working fine. I am running a 24:1 mix. And the guy who sold me the engine said he had taken it out only a few blocks. It seemed to have been sitting in his garage for quite a while.
I also thought it may have been flooded so I got it running for about 30 seconds with the fuel valve off to see if it would use up any excess gas. I tried messing with the c-clip a few times but it hasn't seemed to work. However, i haven't moved it since I put a new gasket on the carb which also seemed to do nothing, but i don't know if i should try the c-clip again?
