wayne z
Best I recall is that the original jet was about .024" I soldered and re drilled to I think .018.
Not sure about the numbers. Just measure the original size with wire drills and calipers to determine it's size. I soldered it up and re drilled with my smallest bit which was .018" then tried it on the road. Can't remember if I had to drill slightly larger again or not.
I just used a standard gun type soldering iron and acid core solder.
I bought my microdrills and hand driver quite cheaply on Amazon.
