Best oil filter to run on a China Girl? Is the Serve Pro ok?
Discussion in 'Motorized Bicycle General Discussion' started by LandSpeedRecord, Jun 17, 2015.
  1. Slogger
    Slogger Member
    Sep 8, 2014
    545
    I forgot, you have to flip em over and make sure they're all he-rats.
    The lack of, um, company keeps them kickin out the ponies from frustration.
    Did you ever get so mad at work you became a dynamo and did like two days work in one afternoon?
    Same deal.
    Check em all for a twig and berries, or get a lot bigger cage cuz you'll need one, cuz.
  2. 2door
    2door Moderator
    Staff Member
    16,310
    Drilling lightening holes in the frame is good but you'll want to start with the front fork. Drill as many holes as you have room for. The lighter the front end, the more weight will be distributed to the rear wheel where the drive friction is. But, always remember to lean back when accelerating or over rough terrain. You don't want to put too much pressure on that front end.
    Fuel additives are important too. Model airplane fuel with a minimum of 50% nitro is recommended. Slack off on the oil ratio too. Oil doesn't burn and will just slow you down. I like the 1000:1 ratio for top performance. But watch your plug color.
  3. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Yes... Pluc color is very important when running that much nitro with that little oil... I keep an extra spark plug duck taped to my handlebars so I can see if it's changing colors while riding, it always looks to be a little on the lean side but I hadn't blown an engine yet so I must be doing something right... and if the spark plug does get the wrong color, I keep a small bottle of touch up paint in my tool bag just in case...
  4. maniac57
    Oct 8, 2011
    4,486
    7
    I have found huge gains by inflating the tire with pre-lightened air as well. I save at least 60lbs per tire by having all the air pre expanded and deheavilized before inflation.
    Another route to investigate is the potential gains from adding magnetic levitation bearings to the flywheel for friction free acceleration with none of the drag conventional roller mains usually impart.
    I figure a 9v battery and a few superconducting magnets is all you need....
  5. LandSpeedRecord
    Dec 11, 2014
    604
    You guys are spot on with plug color. Just make sure and paint on the proper color BEFORE holding it wide open for extended runs. As far as mag lev bearings I found they made the time dilation even worse combined with my running the fuel line past the magneto. I actually wrote this last week and had to wait for the appropriate time to post this for relevance.
  6. Davezilla
    Mar 15, 2014
    2,708
    I actually put another post in here next week but I'm still waiting for time to catch up so the post will show...
  7. LandSpeedRecord
    Dec 11, 2014
    604
    Maybe we can get the mods to adjust the site time zone? There must be something in advanced settings.
  8. 2door
    2door Moderator
    Staff Member
    16,310
    I just discovered something after maniac mentioned a 9V battery. I hooked one up to the 'white wire' and actually broke my speedometer. I guess it was only meant to go to 99 mph and anything over that stressed the electronics. Now all it displays is the words, "Oh Wow".
  9. ckangaroo70
    ckangaroo70 Active Member
    May 13, 2011
    818
    52
  10. Chaz
    Chaz Active Member
    Jun 3, 2012
    973
    54
    Bicycle Repairman!!!
    see how he uses that spanner, watch and learn
  11. maniac57
    Oct 8, 2011
    4,486
    7
  12. LandSpeedRecord
    Dec 11, 2014
    604
    Ha ha ha awesome video!!!!!
