Best oil filter to run on a China Girl? Is the Serve Pro ok?
Discussion in 'Motorized Bicycle General Discussion' started by LandSpeedRecord, Jun 17, 2015.
  1. LandSpeedRecord
    Dec 11, 2014
    604
    [​IMG]
    Here is a pic of the one I am running. It's technically a cross over from an air cooled 4 stroke twin. Just wondered what all the experienced builders are using and help any new people with good advice. I admittedly use the Serve Pro because I get them at a discount at work and can change it often. Remember, oil is the lifeblood of your motor.
  2. 2door
    2door Moderator
    Staff Member
    16,304
    29
    I'd try it but all of my engines are the early design without a place for a filter. I always pour my oil through an old sock to filter it before it goes in the engine :)
  3. scotto-
    Jun 3, 2010
    6,530
    6
    I just screw those type oil filter on to the end of the exhaust pipe to filter the oil from the exhaust before it enters the atmosphere. It also silences the exhaust pipe nicely.
  4. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    I personally use mobil 1 full synthetic oil filters, but that should be fine if you change it as often as you say.
  5. Chaz
    Chaz Active Member
    Jun 3, 2012
    933
    42
    I used a cheap one once and the bike vibrated so bad my nuts fell off. Just a warning.
  6. LandSpeedRecord
    Dec 11, 2014
    604
    Great tips everyone! When I have time I will post my rocker arm adjustments and a short cut I figured out.
  7. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    Are you running oversized valves? I heard 1mm oversized valves at a bit more flow to these guys.
  8. LandSpeedRecord
    Dec 11, 2014
    604
    I am running 1mm over on the exhaust valve and stock intake. My own theory on keeping the intake velocity as high as possible. My next project is an adjustable cam gear and possibly adapting a simplified V-tec system from a Honda automotive head.
  9. 2door
    2door Moderator
    Staff Member
    16,304
    29
    If you're going to use oversized valves then you should also look at adding a cam with higher lift and longer duration. It makes the idle a little lumpy but you'll love what it does at the higher end. Are you using solid or hydraulic lifters? Roller rockers?
  10. Springfieldscooter
    Aug 17, 2011
    310
    6
    My bike goes 4mph faster with a FRAM oil filter.
  11. LandSpeedRecord
    Dec 11, 2014
    604
    Tom, I'm confused? I have to run solid lifters, there would be no way for hydraulic lifters to have pressure on a 2 stroke. And I want to try the Fram oil filter but I am afraid the orange color would clash with my green and blue color scheme negating the speed advantage of the Fram filter. Maybe I should repaint the bike?
  12. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    VTEC would be good, but you might go for the cheap off brand VVT-I which does the same thing, but costs less. Are you going to run a hemispherical head? Have you thought about a port and polish on the intake runners?
  13. knightscape
    knightscape Member
    Jul 29, 2013
    339
    Toe Jam is well known for it's lubrication properties. WD40 is actually 37% Toe Jam. It was discovered in WW2 when the allied soldiers suffered from trench foot and would wipe down their guns with their dirty socks to keep them clean from all the dirt and mud in the trenches. Now it's harvested from the boots of construction site flaggers who stand all day and used as an additive in all the top motor oils.
  14. Southgate Jonny
    May 9, 2013
    90
    I use the Opti-2 oil filter... It's less than half the size of the Serve Pro.
  15. LandSpeedRecord
    Dec 11, 2014
    604
    I can't use WD40 because it degrades rubber and plastic. I have a rubber intake extension and a muffler I made out if plastic vacuum parts. I am looking into the VVTI do you think it would work with an electric turbo?
  16. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    Electric turbo ONLY if you run an intercooler.
  17. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    Everyone knows electric turbos put out like 40 psi so you have to keep the intake temps down to hold off the knock
  18. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    And don't forget to use redline water wetter to help keep the engine nice and cool in these summer months....
  19. LandSpeedRecord
    Dec 11, 2014
    604
    I ran water wetter in my GSXR race bike since no coolant is allowed on track however mine did fine on straight water also. I wonder how well it would work as liquid air around these funny fin things around my bicycle motor? I am still trying to figure them out. I have scientifically deduced that they will burn the he!! Out of my leg, in very nice lines I might add. On a speed note, I mixed a 1/4 can of blue compression with my fuel and oil today and the acceleration was amazing. I need to upgrade the kanipler pins though because I'm sure this much added power will break them.
  20. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    If you have that much power I'd start running water meth injection at 2:1 ratio of air going into the engine methanol has higher octane rating and will help keep your engine temps down.
