aye captian...we dont have enough power!!
Discussion in 'Motorized Bicycle Trouble Shooting' started by Damian84, Mar 6, 2013.
  1. Damian84
    Damian84 New Member
    Sep 24, 2012
    10
    everyone was soo helpful last time. got all the bugs worked out....i thought. so heres whats happening. i can get her to fire up an run for a couple hundred yards, but she starts to bog in the mids and dies at WOT. BUT... when i put her on a stand with the rear wheel elevated i can run through all the power bands and she screams. I have tested all needle positions and found the one that works the best on my CNS, i think. I have found the right float position. no leaks anywhere. it just seems that the resistance of the road is boggin her down. Im only 150 lbs. why would that make such a huge difference???
    I just wanna shred and ride. gota bunch of snow and i wanna try out my custom snow tires. Im tired of walkin to work.
  2. crassius
    crassius Active Member
    Sep 30, 2012
    3,198
    10
    weird, might be too lean to pull the load while still going OK with no load, might be that getting it off the stand changes angle of carb or something that starves it for fuel, might even be that a tire is rubbing on something when weight is on the bike
    can't give better advice than to keep trying & hope you see something that's causing it
  3. headtrama
    headtrama New Member
    Jul 8, 2010
    889
    Sounds lean, when it does it try turning the choke on to see if it runs better.
  4. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,812
    Air leak, hopefully in the intake and not the case gaskets.
    You running 25:1 gas mix? 2/3 cups 2S oil per gallon?
  5. Damian84
    Damian84 New Member
    Sep 24, 2012
    10
    Intake is solid and vacumme tested. Im using an offset intake that i had chopped and custom welded and de-burred and using good aftermarket gaskets. carb is maybe 1 degree off level. running 24:1 ratio break in on brand new motor. where are the case gaskets again? running middle needle position seems to get it fired up and idling. maybe ill try lowering the clip one more notch and test for lean or rich variable. it just confounds me that the resistance on the tire from the road and the shift kit would cause substantial power loss.
  6. MtDandy
    MtDandy New Member
    Aug 14, 2012
    15
    #6 MtDandy, Mar 7, 2013
