arrow on piston
Discussion in 'Motorized Bicycle General Discussion' started by crassius, Sep 24, 2014.
  1. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,724
    82
    got in some kits today with top end removed
    put 4 together so far & found 2 with piston arrow pointing forward & 2 with arrow pointing back (with locating pins on intake side)
    all from same supplier, all seem same as far as other h/w goes, all machined cranks
    the point: never look at the arrow (if it has one)
  2. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
    I never look at the markings for piston oreintation, I have found as you have they don't always mean the same thing. Installing the piston with the ring end pins toward the intake is what I do also. The one thing I have learned is never assume anything, check for yourself!
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    I have found the same thing from the same supplier. I concure about ring orientation. That's more important than a little arrow stamped into the piston.
    This is one of those inconsistancies like carburetor jet sizes. I've found them to be nebulous. I never rely on the advertised/stamped or published size. Actually checking the orifice size is the only way to be sure of what you have.
  4. crassius
    Sep 30, 2012
    3,724
    82
    Yeah, I see a lot of diff markings at the shop, but this is first time with all in one delivery.
