I've been having trouble with my 80cc motor from thatsdax. Had a long discussion with drhofferber (aka Dennis) on the troubleshooting forum, and I think we've pinpointed the problem, but I wanted to get a second opinion and maybe a little advice for repairing. You can look at the thread "Loss of Power" on the troubleshooting forum for all the details, but here's the condensed version:
-I put together my kit and rode it happily for about two and half weeks. Probably about 150-200 miles.
-I started it one morning and noticed I had a considerable drop in power and after the motor warmed up it would not idle unless I goosed the throttle now and then. The idle improved if I adjusted the idle screw all the way in (most open position).
-I started trouble shooting.. checked electrical system, tried a new spark plug and new plug wire, checked for air leaks, went over the carb, cleaned it out, tried various c-clip positions. With Dennis' help I think I was pretty thorough. After all that, I opened up the motor.
-I found a thick build-up of carbon on the top of the piston and all over the dome of the cylinder head. It was maybe a 1/32" layer of soot coating everything.
-I found some light scoring all around the piston and cylinder wall as well as a few deeper grooves on the piston and through the piston rings, and deeper scoring, through the chrome, on the cylinder wall. (I'll attach a few pics)
So... I think the problem is 1) carbon built up in the combustion chamber, 2) bits of carbon flaked off and caused wear on the piston, piston rings and cylinder wall, 3) loss of power and poor idle are result of poor compression. Does that sound like a reasonable assessment?
My questions are: 1) If I want to get it running again as cheaply as possible, does it make sense to replace just the cylinder, piston and piston rings? 2) It seems likely to me that there is some grit and crud in the crank case. If I do rebuild the top end, how can I be sure there won't be more stuff in the bottom end to get thrown back up into the cylinder and send me right back where I started?
I'll take any input anyone's willing to give. Thanks for looking!
-carkl
-carkl
