Excellent. Looking from above, where is the oil drain plug in relation to the center line of the frame?
I got my engine a couple of weeks ago for $112.00 with shipping... pretty amazing. I've made my throttle linkage up, removed the governor and shroud covering part of the head. Thanks for your Granger link. I've ordered the pulley and belt which should be here mid week. This morning I pulled the H.S. engine and made alterations to the engine mount, extending the slots on the sides so the mount can go higher than I had it with the H.S. I was worried that the engine might not fit in a panther frame and was surprised to discover that it fits more easily than the H.S. did. While the Predator engine is wider and longer, the H.S. is taller and made installation dicey. I may be ale to use a normal sized pedal sprocket now instead of the small kiddie sprocket I needed to get as much vertical space as i could. Greatly relieved that it is going to fit and very much looking forward to trying it out, hopefully next weekend.
Thanks for posting the thread and also thanks to AzBill for his informative installation thread. I think this engine is going to be just right.
SB
