A new follower.
Discussion in 'Introduce Yourself' started by TCB, Dec 2, 2009.
  1. TCB
    TCB New Member
    Dec 2, 2009
    Hello out there to all. New to the hobby, my first kit should be here in a few days. (Grubee GT-5 66cc) I,ve been gleaning your posts for seeds of wisdom, as I understand most instructions are incomplete at best. I,m not a stranger to the tool box, or mechanical knowledge so it should be fun. Here is my first whoop's! I plan to convert my 18gr mt. bike, the problem lies in the current gear selectors and deraileur. They are twist grip mounted and I would like to retain pedal mode.Which seemingly is a problem for throttle placment in power mode. I know I can adapt brakes and clutch with optional levers. But what about this. Lay it on me folks. Thanks
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
    Welcome TCB to the forum, glad you joined us.
    I guess you would have to change your current set-up over to thumb shifters to be able to change your gears, at least on the throttle side.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    TCB,
    Welcome to the forum. I'm not sure of your shifter configuration, handle bar length or other details but I retained my twist shifter on my Schwinn Jaguar simply by sliding it all the way to the first bend in the bars which left me just enough room for my throttle/kill switch. You might not have that luxury due to shorter handle bars but replacing them with longer ones might solve your problem.
  4. TCB
    TCB New Member
    Dec 2, 2009
    Thanks for the ideas, I'll check on the options for both. Some thing to do while I'm waiting on my kit. Thanks, TCB
