There is a lot of discussions going on about after market carbs. So here is a poll to post your results to.
Did your after market carb change anything?
Terry
Terry
I don't believe that the stock carb limits performance until you do much modification to the port timing. If the A/F ratio is good for your conditions, then save your money. I have a bone stock carb on an otherwise higher compression/pipe/ported/intake 66 and it is faster than my old 66 with cleaned up ports/pipe/intake/cns-carb. The old motor needed much leaner jetting than the cns carb had stock, but I cant find jets anywhere for it. The only advantage to a better carb, like a mikuni, is accurate A/F tuning across the RPM range. I run 20:1 to get my stock carb lean enough, even with the needle dropped all the way down. The CNS is much richer out of the box, and needs a smaller main jet. I'll slap it on tomorrow to see if there really is a difference.
This Dellorto was provided by my Buddy Alex (Blue Fox) sponsor. And not by any sponsor of Motorbicycling.com or for me.....The only carb I have had luck with is my buddy's Dellorto, and that one was provided by a sponsor. It takes a little tuning and does have a little better performance. But I can get the same thing out of a stock carb with a little work and it dont cost so much.
