89 gas
Discussion in 'Motorized Bicycle General Discussion' started by 1ceCold037, Mar 15, 2010.
  1. 1ceCold037
    1ceCold037 New Member
    Mar 1, 2010
    26
    I have a chinese 80cc engine kit on my bike. Is it ok to use the cheaper gas or should i stick with the 91?
  2. Hot Wheels
    Hot Wheels New Member
    Jul 7, 2009
    162
    The More Octane The Better. Try A Lower Grade And See If You Feel A Difference.
  3. kbot6789
    kbot6789 New Member
    Feb 26, 2010
    51
    i run 89 in mine just fine
  4. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    I've run 89 to 110, I get better performance and fuel mileage with 89.
    *with stock motor that is
    #4 Dave31, Mar 15, 2010
  5. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Octane has to do with fuel ignition under compression. High compression engines require high octane fuel, so that the fuel doesn't ignite in the cylinder before the spark hits. Low compression engines don't benefit from a higher octane fuel. Unless you've done some crazy head milling or added a Puch head or something like that, I highly doubt these little motors have enough compression to warrant using high octane fuel. Same goes for cars. If you don't get spark knock on 87 octane, you're not going to get more power out of 89 or 91 or 93.
    Some fuel suppliers talk about the different additives in the different grades of fuel, and maybe that might matter over the longer term in a four-stroke engine. No fuel supplier I know of, though, takes special measures to formulate their fuel to run well in a two-cycle. Your two cycle is going to get carbon buildup all over the piston and ports and exhaust from the oil, not from the fuel, and there's not enough additives in the world to make a difference in that.
    If you're going to spend money on fuel, spend it on the oil and the fuel filter. Get Opti-2, so that you can run less oil in your mix. More gasoline in the mix means more explosive power in the cylinder. Use a good metal core inline filter, and change it from time to time. Clean your carburetor once in a while.
    If you're going to be picky about the gasoline you use, be picky about the station you buy it from. Sometimes it's hard to tell, but overall, you're going to get better gas from a clean, nationally branded chain station than from a dumpy, mom and pop place. Gas stations that don't take care of their convenience store sure aren't going to replace their underground tanks until there's a foot of water in the bottom of them, and in the meantime, you're going to be pumping a little bit of groundwater and dirt into your tank.
