Hi KC.
Just to be clear...
You intend to put a huge engine in the worst Wallmart <$100 bicycle everyone knows to avoid?
And then drill it's frame?
Why?
Well, regarding the cranbrook frame, it happens to be what I have, and I'm not sure that
everyone knows to avoid it. I have read both favorable and unfavorable comments on this and other forums. Anyway, it's what I have. Be assured that I am constantly on the lookout for other, better frames that can be had reasonably.
As far as drilling the frame, I don't weld at this time and for this particular project, I'm trying to do as much as I can without it. I understand the reservations about drilling the frame, and I am not 100% there yet. I could (probably) make a plate and pay someone to weld it to the frame. Or I may not.
So for the Big Why, I have two main goals here. One, to learn to build a functional drive train by myself, or at least using all of the good advice on this forum. Two, to collect and experiment with different parts (brakes, hubs, etc) to be used on the next build (the one with the good frame and solidly welded pieces). Once
I find stuff that works, it will be transferred to the next build. Oh, and I have to learn how to get the engine to run too.
This bike, in addition to being a "test bed" will, if it runs at all, be used for leisurely trips from one end of the drag strip to the other. It will not be street ridden, no land speed record attempts or anything of that sort, so I'm hoping that as long as I keep it within that narrow envelope, any problems that I have won't be catastrophic.
I've admired your builds and your philosophy since I found this forum a year or so ago and I hope to learn alot from you.
Thanks,
Jeff
