tnjeff
Finally going to attempt to build a bike (my first) with a 3 hp Briggs that used to power a go kart. I like the old bike look, so an American flathead just seems right. I know I'm going to learn alot on this one, so I'm approaching it as if it's a prototype, with the lessons learned to be applied on the second bike.
Cannonball's build (https://motorbicycling.com/threads/cannonball-builds-a-briggs-and-scrap-iron.60752/) really inspired me. My bike will not be street ridden, mainly used as a really cool pit bike. I had always thought the bottom bracket was a natural place to put the jackshaft, but really had no idea how to accomplish it. Thanks Cannonball! I also like the angle iron mount. Easy, and perfect for a prototype.
I'm going to try either a pz-19 carb or an nt carb on the motor. Need to figure out a manifold. The one thing that's on my mind now is whether I should remove the two stays under the main tube. It's a tight fit. I
could possibly angle the motor forward more, but would I run into oiling problems?
Here's a pic with the motor just sitting in the frame:
I guess it could be tilted forward more. What do you think? Tilt it forward or remove the stays?
As far as the angle iron mounts, it appears that on Cannonball's build holes were drilled in the frame tube and the mounts were bolted on. I plan to do that but, it seems like vibration might enlarge the holes over time. Or maybe not. Who knows how much time that might take if it happened at all.
Thanks,
Jeff
Thanks,
Jeff
