Hammond Egger
I have this bike.There are a number of problems with motorizing it but I don't see the exhaust as being one of them.
29" biggest issue to me would be fitting the exhaust. maybe a custom fitted one will be fine but i'd worry about a stock exhaust.
that bike is aluminum too which are known for having somewhat poor welds in comparison to steel frames. just something to consider.
Here's some Pix, need to get some threaded barrel extentions to extend the studs on the gas tank so the bottom strap will fit. Go ahead a)nd laugh at the rear sprocket setup, has a .040 teflon insulator circle on the sprocket side extended holes on sprocket and rubber with fender washers. got the axial AND radial run-out to .001 and it's good and tight. Basically did this to verify the math I did with the gearing(and I wanted to ride it sooooo bad) Still thinking of getting new rear rim with disk brake holes(and use a tophat adapter from kings), a new 36H 29 rim or a sprocket adapter, probably go with the adapter. For sure needs a front disk or Drum, turning out to be another money pit. It'll be worth it in the long run.
Mac
