MrLarkins, you can buy a blank sprocket from jackssmallengines.com in the go-kart section. No math needed just line up the holes from your current sprocket and drill away.
Class, for homework I want you to pool your money together a buy me a sprocket, but never tell anyone about this.
Would that work?
nice bike in th video, mrlarkins
I don't know right now, but I have machinist friends that would know the easiest way.those sprockets have a 1 inch bore, what is the best way to enlarge this to fit a bike wheel hub?
I must be doing something wrong! I have modded carb, intake port mod, exhaust port mod and expansion chamber with a 36t sprocket and can just get 40mph with a 66cc.
How you guys do it with a 44t sprocket is beyond me!
I would wonder if the speedometer was a little off! you know, the proof is in the pudding! with Jack shaft-yes, going down hill- yes, flat ground, no wind, all motor and bike and rider-no! video, video, video! Ive done enough to these motors to generate as much power as I can and I have yet to reach the 50mph club. unless maybe I weighed about 50 lbs. then maybe!
FileStyle-40mph club!
If you have enough power to pull a 27 tooth sprocket on a 26 inch wheel bike I want to know who built your engine..LOL.In my opinion the 27t sprocket is too low, it would take forever in a day to get that up to speed. plus I dont believe the motor has enough guts to get you at top speed with that size sprocket. I run a 36t on one bike and a 35t on another. and the 35t will run maybe a bit faster but not much than the 36t! A 36 t sprocket may be about the smallest you would want to run and still have some low end and top end.
just my 2 cents worth!
got my shyhawk 80cc up to about 42mph adjusted carb was on 44tooth weight is 120lbs and bottom exhaust tip and baffle blow out just before that a day before and exhaust blow little hole in it near motor mix i am use is 32:1 and i think its due to air flow mix and a tuned pipe would make it work like that but it was burning too hot motor got hot very hot in about 2 mins at full throttle i was far from home and had to ride it wide open at that speed think it would be pushing it to make it scream all the time
