27 tooth sprocket
shiloh0
88
MrLarkins, you can buy a blank sprocket from jackssmallengines.com in the go-kart section. No math needed just line up the holes from your current sprocket and drill away.
those sprockets have a 1 inch bore, what is the best way to enlarge this to fit a bike wheel hub?
MrLarkins
HS Math Teacher
Jun 17, 2008
487
49
Arkansas
Class, for homework I want you to pool your money together a buy me a sprocket, but never tell anyone about this.
Would that work?
It just might!!! rotfl
but I was thinking there are a lot of members here, and maybe, just maybe, someone has one lying around, and then maybe they may be a nice member and give it to me.:rolleyes:
Tj Bunch
139
Hey Nice Video But you really should change your Screen name your Too young to be MR. Larkins Untill I saw the Video I pictured this white haired Semi bald old guy riding one of these things......Sheesh so much for sterotyping......LOL
Greg
shiloh0
88
well i took the speedo off my cruiser and stuck it on speedymcschwinn. sadly, i was wildly over-estimating or calculating top end. 41 mph is the top i could attain. i think the exhaust is holding it back i need a better pipe
shiloh0
88
well i realized today that i installed this wireless speedo sensor backwards, so my prior test is no good. prolly why it said i was going from 20 to 45 in one second. and that negative symbol too...you can't outgrow knuckleheaditity
Andyinchville1
Manufacturer/Dealer
Dec 26, 2007
502
Scottsville, VA
HI,
Easiest way for a DIY center hole enlargement (depending on how much material you have to remve) may be the simple grinder (i.e. dremel or drill with a stone)...
For larger amounts of removal it would be best to take a piece of wood (2X6 or so) and bolt the sprocket to that wood using the 9 hole mounts....Next find the exact center of the sprocket....Mark the wood and take a metal hole cutting bit for your drill and drill it out...
Hope this helps.
Andrew
TLDove
18
Lebanon,Pa
got my shyhawk 80cc up to about 42mph adjusted carb was on 44tooth weight is 120lbs and bottom exhaust tip and baffle blow out just before that a day before and exhaust blow little hole in it near motor mix i am use is 32:1 and i think its due to air flow mix and a tuned pipe would make it work like that but it was burning too hot motor got hot very hot in about 2 mins at full throttle i was far from home and had to ride it wide open at that speed think it would be pushing it to make it scream all the time
mobike91
111
2
18
lebanon, oregon
i call bs. my motor kit with a 44t would only do 37 toped out to the max. i added the 36t on there and now can do 45 pushing it. i weigh 160 and my bike is fully modded out with everything plus plus. and it only raps out to 6000 at 40 mph
FileStyle
719
7
Decatur,IL
I must be doing something wrong! I have modded carb, intake port mod, exhaust port mod and expansion chamber with a 36t sprocket and can just get 40mph with a 66cc.
How you guys do it with a 44t sprocket is beyond me!
FileStyle
719
7
Decatur,IL
In my opinion the 27t sprocket is too low, it would take forever in a day to get that up to speed. plus I dont believe the motor has enough guts to get you at top speed with that size sprocket. I run a 36t on one bike and a 35t on another. and the 35t will run maybe a bit faster but not much than the 36t! A 36 t sprocket may be about the smallest you would want to run and still have some low end and top end.
just my 2 cents worth!
kla63
111
NEW HAMSHIRE
ported ,polished,intake exhaust 36 tooth, open air filter , i can get around 50 to 52 mph on straights... it all depends on elavasetion and weather Bro!! warpseedbikes .comdnut
FileStyle
719
7
Decatur,IL
laffI would wonder if the speedometer was a little off! you know, the proof is in the pudding! with Jack shaft-yes, going down hill- yes, flat ground, no wind, all motor and bike and rider-no! video, video, video! Ive done enough to these motors to generate as much power as I can and I have yet to reach the 50mph club. unless maybe I weighed about 50 lbs. then maybe!
xct2 FileStyle-40mph club! dnut
kla63
111
NEW HAMSHIRE
nope !! i've got'n 50mph and i weigh! 175lbs dance1
Allen_Wrench
Resident Mad Scientist
Feb 6, 2010
2,784
26
36
Indianapolis
The brand of your speedometer, the thickness of your tires and air therein, and probably other variables I can't think of right now, all affect the credulity of this 50 mph claim. A three mile straight run, averaged, and measured by a calibrated GPS, might come close to convincing me. But even a GPS falls short of 100% accuracy. Trust not thy speedometer, for it will LIE to thee.
motorhead419
ohio
If you have enough power to pull a 27 tooth sprocket on a 26 inch wheel bike I want to know who built your engine..LOL.dance1
breno
411
Syd. OZ
thats unreal man keep'er crackin ;)
