15 mile round trip too much for new build?
Discussion in 'Motorized Bicycle General Discussion' started by sneekypete, Nov 7, 2015.
  1. sneekypete
    sneekypete New Member
    Oct 22, 2015
    16
    I have a PK80 motor in a schwinn legacy, on its second tank of break in gas (5oz of mix per gallon).. I've put a New fuel line in it, NGK B6HS spark plug, and New muffler gasket.. I wanted to take it into town this afternoon, but wasn't sure if it was too early in the break-in process for a trip that far. Mostly flat, paved terrain the entire distance.. I'm 230 lbs, not sure the elevation but I'm in Lawrence KS... Any help or suggestions would be appreciated!!!
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    No problem. Check stuff for tightness once you get there.
    Be sure to vary throttle and speed.
    Perfect for a break-in run.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Ditto: You don't want to abuse the engine but there's no need to baby it either. Let it wind out a few times but just don't hold it there for too long. 15 to 20 second bursts will suffice alternating with some half throttle cruising. Your engine will love you for it.
    But as Joe said; check the critical things for tightness, especially fenders if you have them. Engine mounts, intake and exhaust manifolds, (don't over tighten them) axle nuts, steering gear etc. You'll be good.
    Report back and let us know how your first solo cruise went.
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,660
    70
    bummer, was busy today - too late now to mention to look at how many fins of motor are showing on each side of frame as you look down, so you'll spot right away if it starts to lean left (as new builds sometimes do)
  5. bairdco
    Aug 18, 2009
    6,376
    37
    If it's a round trip, that means you're stopping halfway, right? That's nothing for these motors.
    I put a brand new engine on and rode it flat out about 70 miles one way to a motorcycle show, hung out all day, then flat out all the way home with no problems.
    (You're experience may vary... :) )
  6. sneekypete
    Oct 22, 2015
    16
    Ok, just got back from my cruise.. Aside from me pedaling and separating the wires once, the motor performed excellent!! I let the bike reach top speed about 5-6 times on the open road to town.. It seemed to run smoother on the way back, with even acceleration and sustained pull from the motor without bogging down.. I'd guess that I cruised it about an average of 15-20 mph and topping out at 25-28 mph... Over all I'm pleased with it's performance, but throttle response still seems a bit slow with some bogging during re-acceleration.. Any tips or adjustment suggestions appreciated.. Also, I moved the float pin in the carb to the last setting on the c-clip before the trip-- after which the bike was able to idle without me giving it gas...
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    Just ride it for a few tanks, tweak later.
  8. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The Chinese 2 stroke will perform better with some miles under its belt. Don't worry too much about tuning or top speed until you have a couple of hundred miles on the engine.
    You'll notice an increase in performance as the miles build.
    This is because the rings are seating and the compression goes up. I'd leave the 'C' clip in the second from the top position until you've put some miles on. Even after that the second groove from the top seems to be about the right place.
    Later you might want to experiment with main jet size but leave that until later. There is a lot of information here on carburetor tuning, soldering jets, replacing them with smaller ones, etc. But you shouldn't worry about that for now.
    Congratulations on your first two way cruise. That's always a fun time when you realize you've done it on a bike you've built for yourself.
    Have fun and ride safe.
  9. mogollonmonster
    Aug 26, 2015
    472
    Never gave my motor a chance to argue. I live 15 miles from town. Fifty miles from work. Read my review for more info on that.
    After a few hundred miles start tuning, till then, just check everything.
    Watch your rag joint, I replaced the bolts with grade 10s, the nuts with grade 8 nylocks, and double up on the lock washers. Put one under the head of the bolt, and the usual one under the nut. I did this, and haven't had to retighten since, although I check before every ride. Before, I had to retighten every 10 miles or so, just to keep the sprocket straight.
  10. TheNecromancer13
    Jan 21, 2015
    607
    12
    My break in ride was `17 miles to school 17 more miles back, and on the way home, up a 2000 foot tall mountain lol.
  11. allen standley
    Oct 22, 2011
    796
    20
    No Prob! At first stop check the obvious. Engine mounts, carb, exhaust, wheels, drive line. Give it a good look over
