Davezilla
Ok, I knew it was going to happen eventually, just didn't expect it to happen earlier today but my modified pocketbike pipe broke off at the lower mounting tab. I was going to just weld the tab back on and carry on with breaking in my newly built engine but once I saw just how thin the metal was and that it was even thinner where it broke off, I opted to go ahead and build up my new pipe. This one started life as a 2013 KTM 50 pipe and I got it off ebay last month for $30 because it had a nice dent in the belly section, luckily that's in a non critical area but I hammered out most of it while I had the pipe cut in half.
Here it is tacked together, I had to cut it at the middle of the belly and re clock the baffle cone as well as rearranging the bends at the header inlet area...
And here are a few more pics of it after it was welded up and installed...
Last pic just shows the layback seat post I made yesterday, I actually made it about a week ago but took it back off and welded in a gusset brace because I could feel it flexing while riding earlier so I had to fix it before it got worse...
I was able to start it up just long enough to hear it and it sounds much more like a dirtbike than it did before, even with the old expansion chamber. It also revs a lot faster and has a nice agressive sounding idle... Here it is with just the header from the old pipe, I made it a slip fit at the header so when the bracket broke the header stayed put and intact.... https://www.youtube.com/watch?v=SstiA9_qYs4
