AH64Apache
Hi Folks,
OK I'm finally breaking down and asking for help. I'm stubborn and like to figure things out for myself. Anyway, I installed the Black Stallion 80cc kit on my mountain bike. I've been trying to get it started for about a week now. I tried some things I found here in the forums, but she still won't fire.
Here's what I did just last night. I adjusted the clutch via the "flower nut". Didn't fire but sounded better. Thought it might be flodded so I went through the technique described by Mark (I think) in a post somewhere here to clear the engine. Almost sounded like it was going to start after that. So, I thought I had too much grease in the gears, which I did. So I took off the flower nut and clutch plate. Cleaned the clutch plate and pads (also scapred out extra grease). After I did that and tried to start. It sounded like the motor was working now, but just not firing. So I changed out the spark plug. Still nothing. I changed out the plug on the ignition coil. Still not firing. Then while trying to start it, the chain came off twice, which never happened the 20-30 times before. So now is my clutch too tight? Also, on the last attempt, I think the throttle came loose, or broke because now it twists all the way around
So I gave up last night and drank heavily
Plus as old as I am climbing back up the hill to my house 20 times a night with the bike & motor is getting tiring! Tonight I'll probably take a break from it and go fishing instead after work. Relax, fish and have a few Rolling Rocks!!
Anyway, any idea what it might be? How do you test to see if its getting a spark? Speaking of which. This doesn't seem normal/right to me. The plug that goes on the top of the spark plug does not/will not snap/fit on the top of the sparkplug. Is that normal? To me it doesn't seem right, but what do I know,, I'm new to this.
Also, for priming that motor, I heard they're easy to flood. But then I read that a guy didn't get his to fire until he held down the primer button for a few seconds, twice. I'm just "tapping" mine twice, but I also tried his method. So I'm guessing every engine is a bit different as far as that goes? How much do you prime? I can here the gas going in when I push the primer button. Also, is the choke needed when the motor is cold, but the outside temp is between 60-70 degrees? I tried up, down, middle. Hopefully I didn't leave anything out. Maybe its the throttle? The cable was installed from the factory, so I didnt ever mess with that.
Any help or ideas would be greatly appreciated!
Thanks so much!
Joe
Thanks so much!
Joe
