Wow, that motor is a factory freak for sure!I got up to 50 a couple of times. 80cc schwinn beach cruiser ngk plug/plugwire, 1 gear all stock. You have to push it passed the point it sounds like its going to explode and have a wide straightaway, mine has a 55 mph speed limit, so if u dont go fast you`ll get run over. Its hit and miss 30% the time it breaks down afterwards all vibration issues. Ive been told its leaky and air is getting in and im running rich. but it hasnt blown up yet.
The wheel is 26", the tire can make it considerably larger.The tire is 26''
I don't believe 80cc HT cranks can spin at 13000rpm without blowing up. Or 10000rpm. Even perfectly balanced ones. Most will vibrate to pieces at half that.You don't believe that mine beat 58kph?
And if your tire is 2 meters diameter like you say the torque is so low it's unlikely you can go 2kph.The tire have 2040mm
You want a picture?And if your tire is 2 meters diameter like you say the torque is so low it's unlikely you can go 2kph.
