Masterm222
Both my bikes seem to surge at WOT. They don't seem to rev like they should. I forgot to turn on the fuel once and the bike ran like I had NOS just before it died. What would you suggest? Solder and re-drill the main jet smaller? Shave the piston skirt? I NEED HELP!
by norman
right before it ran out of fuel the bike went leaner that is why it felt like nos. You might need a one size leaner main jet. should also stop the engine surging at wot.
by norman
Need a little help. I can't seem to get the needle and seat to seal. Clean and adjust as much as I want and the fuel level is always above the level of the gasket. Faulty seat or needle? Tried a brand new carb and same thing. Solution, new mukini 18mm carb? Could this be caused by engine vibration? I could hose mount the carb to eliminate some vibration. This motor seems to run reasonably smooth but I suppose it is still possible. Anyone go through this problem before? HELP!
Bad dead spot around 19 to 22 about half of the time but after that it gets up and goes. I figure the bike with the carb problems has such good low end power but no top end really needs more than one gear! Then maybe it can keep up!
What am I going to do when I have my Giant Stiletto chopper built and running?! Then I will have three to tinker with!
loads of midrange
and a high enough top end to keep me smiling.
