Giant Simple good start for Chinese kit
Trae
I have been offered a 08 Giant Simple for $50 and just got my engine today for what I though about modifying a full susp bike for. I just have to drive 3 hrs to pick it up. Any one use this frame any pics? Definately would be easier to mount the engine from the looks.
after deciding I hate the way the sprocket mount I bought a Manic Mech Spocket mount and sprocket and will just get the cables set up.
where did u get that front mount from?
made it with an exhaust clamp. I had to make a slight redesign though. I used abigger clamp also so i could put the silicone tubing around the frame to absorb some vibration and protect the aluminum frame.
I have the same issue with an oversize aluminiun tube. What size clamp did you get? The one I have now won't allow to use a rubber tube to aid in vibration suppression.
the clamp is 2 1/4". I could probably use a 2" though. I ended up making a plate to offset the mount, so I could mount the enigine lower b/c the carb wouldn't fit.
is that a single, doulbe or triple wall aluminum....?i have a gary fisher, triple butted...put steel pipe around the frame, threaded it and drilled a clean hole thru both front and back mounts...so far so good..placed it high because of the mounts and i have no vibration...and the nuts stay put nothing loosens up...now isnt that strange...
it might fit if you buy a intake from manic mechanic...12.00...than mill or grind the surface at a angle...and its straight...will leave you more room...your clutch cable will have to be changed...will send the pic for that or i'll put it in another...spooky tooth is where i got the expansion pipe...nice hu....kicks a...in the low end...little noisy but a classy sound...hope this helps...now your aluminum bike...is it a single,double or triple but frame...Dennis.....it shifts easy...
no...i talked to them about a month ago and they said it would be about a month before they would be restocked...give them a call and give them a shove...Dennis
Where's the rear motor spacer? Or is there a reason you didn't use it? It looks like a nice bike. Sick Bike Parts sells expansion chambers too but I think they are sold out right now too.
