If you do go that way, you can now buy just the engine without the kit parts and use your old kit parts.
The little thing he left out is what got both my rings broke... You have to find the little nipple inside the ring groove and make sure the opening in the ring is round it. otherwise that little nipple will break the ring. If you run your finger around the groove you will find the nipple and can position your ring correctly. Mine went in easy after that and no damage. didn't need a compressor just worked it in by hand.What have you found out so far? Are you ready to put it back together?
Re-installing the piston/ring isn't that hard. Lots of light oil and some deft fingers and it will go right in. Or....you can buy a cheapo piston ring compressor from J.C. Whitney or rent one from the local auto parts store.
Just tip the piston on the wristpin bearing a little and start it into the cylinder.
Piece of cake.
Sorry I don't have any pictures of if but there are some pics somewhere I have seen them before. That little nipple thing is why I said to be sure to ask before you try to put the piston back if you haven't done it before. Otherwise it really is simple.
I'm no expert, but isn't snowmobile oil supposed to be more sooty/ashy or something? I would try using a different oil.the needle clip is 2nd from top. fuel mix 25:1 with snowmobile oil. I put a new plug in yesterday and after 10 minutes it was black. Should I try mixing 30:1 ? Move needle to top clip ? Mix pee with it ? Or what ?
Well I just didn't want to offend you. Your advice is always right on, sometimes I tend to think everyone is as dumb as me lol. Honest I had no idea there was a bump in the ring groove. I worked on a lot of cars but this is my first time inside any engine at all. If my engines needed that kind of work I took them to the shop. This has been a really good experience for me.Exellent!
deacon- did I seem terse in my reponse? Sorry if I did. Sometimes I forget that everybody hasn't been working on i.c. engines since they were knee high to junebug and I assume stuff.
I saw a guy try to screw on his carb up side down once (on a dirtbike) and when I laughed at him he almost gave me a knuckle sandwich. I just assumed that everybody knew they didn't work that way.
