Check The Fuel Mixture. If Its Not Broken In Use 16:1. Check The Carb For Leaks Around The Intake Manifold. Use A Ngk Plug With Proper Gap + Use A Better Plug Wire. If Its Dripping Oil From The Pipe You Probably Got To Much Oil In The Gas. Hope This Helps
I Don't Know Everything...but I Know What Works.
