New Whizzer owner
PedroGJr
Bought 2 same day the red Pacemaker came with title came with about 300 miles left turn signal currently not working everything else great buy.
The black panther no idea what year broken throttle but runs. No title
How can i get more power out of the Pacemaker I was looking for bigger carb but could not find anything same thing with copper head bike top speed has been 30mph struggles uphill if I don't have a head start to build up to 30 mph
Bought both for $300 btw
Perhaps @Wrench will have some advice for you. You may want to use a Direct Message by clicking on to his name.
Politicians have destroyed the market for Whizzers in several states where they have to be registered as a motorcycle because of displacement. Riders figure they might as well just buy a motorcycle with more features, a modern engine design, and a transmission. I sold mine when the state tightened requirements for motorized bicycles, Instead, I started making Whizzer-type bikes that meet the 50cc requirement. There has never been a liberty in history that politicians didn't want to trample. Aside from that, you got the deal of a lifetime. The best thing you can do to get the most out of both bikes is to make sure they are properly tuned and make sure your belts aren't slipping. When I got those things right, my ole Whizzer would easily do 40-45 MPH and on a good day I could outrun my buddy's Cushman! I think Wrench gets higher speeds from his Whizzer. I'm currently tinkering with the jetting on a Huasheng with a Keihin carb. Assuming your bike has the same 19mm Keihin, there is a wide range of jets available if you want to de-restrict the air filter and exhaust.
Yes i would love to de restrict do you have links for jets im sure everything is original on my red Whizzer everything works except battery but the it is currently not going faster than 30mph.. after I thighend the tire because the chain was slipping and I've been messing with carb also
There are a thousand sources. Some are Sudco, Jets R Us, and Summit Racing. The key is to have the model of your carb and, if possible, the part number for the jet you need. It just takes some digging and some patience. New jets won't help if the timing, the spark plug, crankcase vent, and belts aren't right. And a free flowing filter and exhaust are needed to allow the engine to burn the extra fuel from a larger jet. Finally, a Whizzer is a little squirrely over 40 MPH. I had to swap out the rear coaster brake for a 203mm disc to feel safe. Good luck and have fun with your new toys.
Real good find on the 2-
