Dave's Tech Service-PA
Finally stumbled onto a bracket with dimensions! 98.7 is about 3.877, the measurement for same adaptor was about 80mm is about 3.149! So, I sent text to the vendor, what size is it? I doubt they even know, just a part in a warehouse with generic diagrams.
Again, “presumed” all 3-hole adaptor are the same!
13.7mm is a huge difference!
I have to say, I’m a bit disappointed that no one can chime in on vendors and product information?
Isn’t this what this forum is all about?
From the several who've used them. They said they had to drill a hole in them so that they could be pinned. This prevents them from slipping.
The 2-speed hub wouldn’t function if the adapter were pinned. Even so, can’t find an adequate adapter to fit well enough to pin! lol
Seems every turn there’s a component issue. Engineering comes into play.
I kinda hoping more parts would be readerly available
Thanks
Thanks
I personally like using a 3 speed internal geared hub that has a disc rotor mount to mount the sprocket. Then you can use rim brakes for the rear wheel
I personally like using a 3-speed internal geared hub that has a disc rotor mount to mount the sprocket. Then you can use rim brakes for the rear wheels
(Hub diameter is 40mm/1.68 so a 1.5 adapter would need machined) Or bolt the sprocket to the left flange of the hub, or even both Just get sprocket 40mm ID
The drill site for 6-bolts is .2200 diameter
The one sprocket comes 57mm ID and the 3 countersunk holes for the (adapter/adaptor)?
(I came up with 8 bolts)
77mm-diameter bolt pattern
40mm-hub id
57mm-sprocket bore
89mm-hub flange diameter
May need a slight rotation on the 3-hole positioning, or reduce bolt holes to -7
Finally prepared the rear brake boss for weld, measured three times with two different 26” wheels for reference
Tig
Very close tolerance for cantilever, v-brakes will not fit this position at all
Decided to changeover to the single speed coaster brake S 7 wheel.
(Opened up the 1.5-1.69)
This allows a good 6/1000th of material running 52T-415 chain sprocket
Loosely fit here, looks to be just about right!
The machining process was simple enough keeping things square & true.
(Helps having a friend with a lathe)
Additional support via a set bolt is next
The shims make the difference in getting a square three-point fit and true .6-th gap
The “Mock-up”
Centered there’s plenty of clearance for the wide pedal crank
The front profile looks awesome!
The sprocket alignment off the “Death Row” CVT is dead on
Not liking this “bolt in” motor mount!
Going to fabricate a 1/4” steel plate and Tig
Looking down its intimidating Ducar 212cc!
The mark up for rear fender & fuel tank/rack
The rear view with shut-off
The fender cut away keep that pesky chain from chewing on it!
The chain route to the CVT
Top view fuel tank/rack
This is loose “adjustment phase”, may need to come forward on the rack.
Roughed in the 1/4” steel plate, fits “good & tight”
Notice the cut away for the chain
The adjustable mount makes alignment a breeze
Repurposed the old medium fenders
Then double check clearance, literally almost non-existent!
