Carb recommendations
Mikenflorida
7
4
3
57
I’m so tired of trying to find the right jet for my carb that won’t be too rich. I’m looking for recommendations for a good carb with an air fuel mixture screw. I just have a regular china girl. Thanks
Tony01
1,840
1,947
sf bay area
I’d try to find the right jet first before swapping carbs. You can fill a big jet with solder then drill it to the size you need.
I’ve heard good things about those tillotson style china knockoff carbs. I can’t confirm or deny fitment however.
  • Like
Reactions: Gordy
Tony01
1,840
1,947
sf bay area
You don’t need to continue to make new threads on a common easily fixable and searchable topic. Did you try the solder method that we suggested?
  • Like
Reactions: Gordy
Tony01
1,840
1,947
sf bay area
No. I’m not good at soldering. I would just like to get a better carb.
You don’t have to be good at soldering all you have to do is plug up the hole. Nobody who does wiring is good at soldering their first time. It’s easier than making a new carb work. Well you’re the one asking, I gave my best advice, well I tried and that’s all I’ve got… good luck
  • Like
Reactions: Gordy
Mikenflorida
7
4
3
57
I appreciate that but I’m looking for a carb recommendation
Venice Motor Bikes
Mar 20, 2008
7,331
1,962
Los Angeles, CA.
Years ago I bought a Whizzer that had one of those Walbro carbs with fuel screws... I couldn't for the life of me make it run good!! :(
Finally I gave up & swapped out a cheezy Chikuni carb onto the bike, & with a simple jet swap, I quickly had the bike running like a champ!
Mikenflorida
7
4
3
57
Better carb for what?
Cruising lawfully down the road NOT attracting unneeded attention getting the bike nazis to crack down farther,
or better as in I'm gonna keep it on the track and be responsible?
Gordy
19
31
13
17
East Kentucky
An air fuel mix screw is only gonna get you so far. You're still gonna need to play with jets. Just take the smallest jet you have and start drilling the size out until it's right. Jet drill bits aren't super expensive.
  • Like
Reactions: Wevil Kenevil
Wevil Kenevil
460
428
Sack a tomatoes California
You are sooo all over the board you can't see straight... (slaps you sober like daffy does porky)
Ok since you don't know how to read post do this...
Start with original carb and jet. (Nt with a 70 main jet)
Go w.o.t. and do a plug chop. Adjust your jet size or needle setting accordingly.
  • Like
Reactions: Gordy
Wevil Kenevil
460
428
You are going down a huge rabbit hole. Start with stock parts and work your way up. The direction you are headed is probly not going to win you any friends or much friendly helpful advice.. trust me.
Spend just 2 hours reading forums.
Magical Jedi powers,you will have.
  • Like
Reactions: Gordy
