Mikenflorida
I’m so tired of trying to find the right jet for my carb that won’t be too rich. I’m looking for recommendations for a good carb with an air fuel mixture screw. I just have a regular china girl. Thanks
I’d try to find the right jet first before swapping carbs. You can fill a big jet with solder then drill it to the size you need.I’m so tired of trying to find the right jet for my carb that won’t be too rich. I’m looking for recommendations for a good carb with an air fuel mixture screw. I just have a regular china girl. Thanks
No. I’m not good at soldering. I would just like to get a better carb.You don’t need to continue to make new threads on a common easily fixable and searchable topic. Did you try the solder method that we suggested?
And I have searched but haven’t found an answer. Please helpYou don’t need to continue to make new threads on a common easily fixable and searchable topic. Did you try the solder method that we suggested?
You don’t have to be good at soldering all you have to do is plug up the hole. Nobody who does wiring is good at soldering their first time. It’s easier than making a new carb work. Well you’re the one asking, I gave my best advice, well I tried and that’s all I’ve got… good luckNo. I’m not good at soldering. I would just like to get a better carb.
I appreciate that but I’m looking for a carb recommendationYou don’t have to be good at soldering all you have to do is plug up the hole. Nobody who does wiring is good at soldering their first time. It’s easier than making a new carb work. Well you’re the one asking, I gave my best advice, well I tried and that’s all I’ve got… good luck
What you do is you make a plug of solder in the orifice of the main jet and just re tap the hole with a needle and working your way up. Welding files in the blue case, you find on ebay for $1.99 have the size orifice file needed to port your main jet.No. I’m not good at soldering. I would just like to get a better carb.
I’m so tired of trying to find the right jet for my carb that won’t be too rich. I’m looking for recommendations for a good carb with an air fuel mixture screwBetter carb for what?
Cruising lawfully down the road NOT attracting unneeded attention getting the bike nazis to crack down farther,
or better as in I'm gonna keep it on the track and be responsible?
Post a link to where you found it?Update: I purchased a Runtong 2 Stroke Tunable CNS Performance Carburetor V2 and it worked perfectly right out of the box! Other than having to adjust the idle, it’s running great! Highly recommended!
