The CDI is new and changing it wouldn't fix it at all.I had a CDI that worked fine at idle but when the RPMs raised the engine would miss
I checked everything but a new CDI fixed it
It's a good idea to have a new CDI on hand so you can switch CDI when troubleshooting
BTW extra new electrical parts making troubleshooting easy by switching parts
You sound like you know everything... At this point, why don't you go elsewhere for helpThe CDI is new and changing it wouldn't fix it at all.
Alright, listen, Steve, I've rigorously tested the CDI with a multimeter again, and it's absolutely showing no issues. I'm here asking for help, not to engage in endless back and forth.You came here asking for help and all we get from you is a nasty attitude when we make suggestions that have been working for everyone else for years. A new CDI is no guarantee that it's good given the quality of the parts available. Your non running engine is not our problem. Google is your friend, use it.
Steve.
No wayYou sound like you know everything... At this point, why don't you go elsewhere for help
I was just sharing one of my stories of how unpredictable a CDI can beThe CDI is new and changing it wouldn't fix it at all.
Why don’t you just figure it out then? Yeah, use some brain. You know? Maybe sit and think about it, make a list of other things that could go wrong etc. ya know, figure it out?Alright, listen, Steve, I've rigorously tested the CDI with a multimeter again, and it's absolutely showing no issues. I'm here asking for help, not to engage in endless back and forth.
A multimeter wouldn't play games, right? So, while I get the suggestion, it's pretty clear the problem still isn't with the CDI. I'm determined to get to the bottom of this.
No he will figure it out. He knows better than us anyway. It’s not his carb or CDI he found out with pure mastery of thought patterns. I think he’s fine.Did you ever by pass the kill switch? My builds use a keyed ignition switch. Rabbit foot key chain is optional.
Tony is right, make a check list / algorithm and follow it.
Why?No he will figure it out. He knows better than us anyway. It’s not his carb or CDI he found out with pure mastery of thought patterns. I think he’s fine.
Because.Why?
