Hi new to this site.
Welcome to the forum, I’ve never owned a whizzer so I have no first hand knowledge. I would start at the new carburetor since it ran with the other one. Is it a new or used carburetor? If it’s used I would disassemble it and clean all passages, varnish build up is the most common problem with small engine carburetors.
It ran at high idle with the old carb, it got me around the block but if I tried to give it throttle it didn’t like it.
Got a used whizzer, can’t get it to run properly, any advice?
Start by checking the valve lash IN .008 EX .010
What size carb did you get from Paul
BTW how many miles on your WC-1
Timing dot on the cam gear was stamped one tooth retarded on purpose by Whizzer for EPA reasons
The cam may of already been advanced by the previous owner, but check anyways
Take off the RH side cover and advance the cam gear by lining up the cam timing dot to the crank timing dot one tooth counter clockwise, This puts the cam in the correct timing position
How about posting more pictures of the other side of the carb (& also the pictures of the old carb that I asked for)...
I'm asking for lots of pictures because they might help someone spot a problem!
This is the original carburetor, it was not on the bike when I got it
This is the one that was on the bike
Not that I know much about Whizzer Engines, but see that air filter and exhaust/muffler are not clogged.
As Click & Clack would say nothing can go out if nothing can go in.
Two of my Briggs 4 stroke engines had problem trying to use foam airfilter. Had that effect of only running short time. I bought the holder to switch to paper airfilter used part on Ebay. Got it back to running.
Valve lash every 5 years it has the gap go to zero on intake. Exhaust some of that too going to less lash.
With intake lash getting smaller eventually I get wet paper air filter. This is the result of venturi effect in opposite direction. Intake valve open too long into compression stroke on a 4 stroke engine. Wet paper airfilter starves engine for air intake.
Two stroke engine on a Lawn Boy Mower had grass and carbon at the exhaust. The build up that cause back pressure after just about 1 second of run time and then stall out, was fixed by cleaning that junk out. Have to credit my Dad about that fix. I was messing with ignition which was wrong in this particular case.
MT
Am I missing something here ? The picture of the engine shows the carb mounted on the side of the cylinder like a 2 cycle. Everyone keeps talking about valve settings, what valves ? The replacement carb is a better carb, but make sure it’s level.
