I've been searching for the parts to remove the Huasheng 49cc 4 stroke Rev limiter (some call it a governor I believe erroneously). The process to do this is detailed in a few threads here. One from a long time ago that I cant find and a more recent one called something like
Ungovern Huasheng 49CC
The rev limiter is eliminated by using the Honda gxh or gxv 50 Flywheel and CDI.
The problem I'm running into is the Honda CDIs I can find online all look identical to the Huasheng Rev limited roundish CDI that has the plug wire in front if your looking at it on the engine.
The Honda CDI that I'm familiar with that will work in removing the Rev limiter was more square and the plug wire was in the back when installed on the engine(the old Huasheng 49cc CDI used to be the same but much longer ago).
Can someone tell me where to find the apparently older Honda CDI and Flywheel?
Is there a different CDI Flywheel combo I can use to remove the Rev limiter from Huasheng 49cc engines?
I'm guessing someone will bring up the 53cc Huasheng that's not rev limited or governed but I'm almost positive the TCI round barrel ignition it comes with is not available. However, if someone knows specifically where I can definitely find it then I'd appreciate the input.
