On a scale from 1-10 (with 1 being completely unreliable, and 10 being 100% reliable) how reliable is the Mongoose Excursion 29" frame? Would this frame be prone to cracking with a 66cc engine on it?
It has a steel frame,On a scale from 1-10 (with 1 being completely unreliable, and 10 being 100% reliable) how reliable is the Mongoose Excursion 29" frame? Would this frame be prone to cracking with a 66cc engine on it?
I was about to do this bcuz the regular mount would not fit, nor the U bolt, but I decided it was not a good idea so I just bought a Beach Cruiser U bolt, that is slightly bigger than the stock one (or so I've been told). Awaiting deliveryIf your M/B kit instructions tel you to drill a hole in the bottom frame tube for the motor mount Don't do it This will make your frame crack
Department stores don't make bicycles for extremely tall people around 7' tall. What you have is a bicycle with 29" wheels not a 29" frame. Here's a bicycle frame calculator that'll tell you what the ideal frame would be for you if you had one custom built.On a scale from 1-10 (with 1 being completely unreliable, and 10 being 100% reliable) how reliable is the Mongoose Excursion 29" frame? Would this frame be prone to cracking with a 66cc engine on it?
