Hey guys I've got a question, I recently purchased a monster 90 (79cc) with a macari chopper style frame off of craigslist, from this kid, he told me, he couldn't finish, the build because, he didn't have the time, he had to move up a little ways north, because of work reasons, something like that, anyway
The motor was basically brand new, to me it looked like he had tried, or had started the motor, only o few times@ most,
Well when I find Nally got to t together, because he had a couple things, like the transmission, and a few minor things installed, up-side down, or even hackwards, anyways, as it stands right now, the motor will fire up,( only after a really hard/cold start), but when I finally get it to start, after, at least 7,8-maby 10 minutes, of pulling pullstarter,and starter fluid, anyway when I finally Nally get it started, and warmed up it will idle on its own, but when I give it gas there really no power, to speak of, sometimes(or mostly there's a little Power, barley moving, after a minute or so of coaxing it it would start to make me approximately 4/5-maby7 mph,, after I ride it a few blocks, I staop, kill motor from r a minute, then I would hear this air hissing sound, not really loud, but I can hear it, non-the less, so I tracked down the source,
I noticed there, was a pretty good amount, of oil, leaking, from the top of the motor, between the oil, and the air leaking out, coming from the motor, anyway the source, was the air handler SS ng sound, and I leaking oil, I found out, was coming from the governor mount/post, i watched several videos from "youtube" and Basiclly, they said, that leaking oil from he governor hole/post, was normal, or brand new 79cc preditor motors, that after break-in, the oil would stop leaking, , basically it would eventually, seal it's self,
Before I never really heard/noticed any air, leaking from there,
When I first got it together, it would really start, or I should say it would either not start, or something'f it would start, it would start, then die imediatly afterwards, so a friend was looking at it for me, and we was watching more. VIdeos, we noticed, there was play, and the gov arm wasn't fully engauging, also checked the carb jets, and the jet undrneth idle screw(p/15)carb
Was clogged, so I cleaned all the jets, then put everything back together, it actually started right up, it seamed to have a little Power, but was still slow, to build speed, right from start-up, but once it got moving it would move pretty good, I rode with it approximately 3-4 miles, turned it off, and the next morning, tried to start it, and I couldn't get it started, then I remembered I needed to put a fuel filter on it, so I cleaned the jets again, and put filter on,
With some coaxing, it started, but this time after start-up, when I try to take it off, there basically was no power, even after coaxing some speed out of it(2-3-maby 5 miles per hour,there was either no power, or it would die, I could get it to idle on its own, but on the take off, it would die, or it would have no power, that's when I heard/noticed, the air hissing sound after turning off the motor, also not really excessive, but deffinetly really noticeable,
Could somebody "HELP", Me, with some ideas, or suggestions, why this motor, is doing this????also info on how to fix this problem, I would be greatly appreciate, any, and/or all ideas or suggestions, on why, and a way to fix this problem
