Tony that's truth & the Treatland wheel is dang sure priced to sell. You'd be right to think there's a "but" coming and there is. Those just coming into this hobby don't yet have a clue and many who've been building for years using sprocket clamping adapters and CG engines are doing fine on non DOT compliant tires and wheels at 25 mph cruising speed. Some can't or won't spend money to convert bikes that are ridden at pedal bike speeds, nothing wrong with that. Others have bike frames & forks that won't allow the wider profile tires to fit. Not a problem for advanced builders but for the novice it's a daunting task when they struggle just to break down a tire or fit a chain.This is the easiest solution. Sprockets from 40 to 60t, brake, freewheel, 17” tires can be found just about everywhere from moped tires to small motorcycle tires. All setup for a 12mm axle. And it’s a rear wheel you can grow with. No sudden problems when you move up to a bigger motor with a rag joint.
https://www.treatland.tv/17-black-bernardi-five-star-REAR-mag-wheel-p/bernardi-blk-rear-5star.htm
Not confused at all- thank you. I will be using a handy CG160. I actually bought 3 of them - $50 each. I’m debating how to mount it now. Thought about welding (I need to learn to weld) in a mount, but if I find something bolt on I might do that.Have you decided if your going to power this bike with a China girl 66 cc or a small 4 cycle motor? This will make a real difference in the sprocket you select as will going with a CVT on a 4 stroke. Your weight and terrain also enter in to the sprocket decision. Rule of thumb with 4 cycles was 48 or larger and with 2 cycles 44 tooth or a bit smaller...seldom have I seen the need for more than 48 tooth on a 2 cycle CG. The use of CVT's on 4 strokes has changed the rule of thumb for 4 strokes depending on the CVT pulley ratios you can utilize smaller sprockets final drive.
Just something to confuse you with I'm afraid.
Rick C.
That got me to looking at Honda engines. Maybe the Honda GX100 "100cc" could be a drop in replacement for 79cc predator? Just looking at the picture it has the advantage of looking very much like the GXV50 "50cc" Would have to research transmission options. Being a Honda it could be better built.Well I'd probably go with the 3 D manual clutch using a bottom bracket style reduction sprockets & wide pedals. The GC 160 make about 5.5 hp at 3,800. So I'd try 12tooth motor output to 24tooth reduction input to 10 tooth output and depending on what cruising speed I want....select a rear sprocket I'll calculate whatthat looks like with a 26" rear wheel and get back to you in a bit .
That's theoretically 45 mph with a 38 tooth rear at 4,000 rpm, just as an example that will give you an idea of what to expect. I'd not spin the GC faster than that with out some valve train works especially stiffer springs. If you disconnect the governor you have to go easy on reving this thing. Single speed.
Moto Mags did a GC 160 with a CVT and he likes it as many have using various engines.
High end cent. clutch like the Bully is also a proven way to build a drive train and using the reduction drive I described above, but with different drive ratios. Jack shaft can be used in place of the bottom bracket reduction drive as well on the 3D and the Bully clutch ...Sportsman offers a specially modified version of the Bully for use on moto bicycles rather than go carts that are setup way different for small diameter tires.
None of these are inexpensive setups & all have proven they work. These are three of my favorites, but there are others like the final belt drive with no clutch that are frequently built classics.
Pick your favorite and deal with it, all use 3/4" outputs.
Rick C.
At that price we can build a much better 79cc predator.That GX100 looks great- I was looking at that too. But it’s about $400!!
