Okay because I have this tensioner on it right now and wondering if it would be good or mess anything up. I don’t know much on these bikes yet so thanks for the advice.Yes you can is much better without tensioner, have to keep a eye on the chain for adjustment..........Curt
Well a friend of mine made and said it should work so not sure on that. That’s why I’m wondering if I remove that tensioner and shorten the chain instead that should work correct?That wheel should have a grove in the center for the chain to fallow, the way it looks now it could be sloppy form side to side. ......Curt
Tensioners should be on the bottom of the chain run, not on the top.Well a friend of mine made and said it should work so not sure on that. That’s why I’m wondering if I remove that tensioner and shorten the chain instead that should work correct?
Would taking off the tensioner and shortening the chain work though that’s what iam asking. Thanks for the advice I’ll get to replacing those as soon as this tensioner thing is fixed.Tensioners should be on the bottom of the chain run, not on the top.
Replace the mickey mouse wire on the muffler with a clamp or two.
Would you happen to know if the stock tensioner that comes with kits will work on the bike and how would I put it on the stingray?Tensioners should be on the bottom of the chain run, not on the top.
OK... Lets take a deep breath here and think for a moment. Common sense says the pic you uploaded shows a very busy and troubling area. Everything is wrong! That brake is in the way and should be a different set-up. The muffler may need to be re-located and at least properly secured to the frame somewhere. The tensioner if used at all should be thought of as a guide not somthing putting tension on the chain. As said above it must be @ the bottom of the run not above. Remove the home made tensioner and wheel, that's just plain wrong. After undoing all that is there, take a wider pic showing the chain run from the engine on back to the wheel sprocket. Your issues (in my humble opinion) began when you mounted the engine. I have never built a Schwinn Stingray. Many others have. Do a search "Schwinn Stingray" Ideally some where is a posted pic of the Left side of bike. That will give you an idea. You need to do this safely. Don't get discouraged. Others have done this. Here is your link.
https://motorbicycling.com/search/10463351/?page=3&q=schwinn+stingray&o=date
Okay let’s answer these questions one by one, the brake is not in the way or hitting anything it may look like it but it might be the angle when the clutch is in the chain tightens up . Don’t worry about the muffler it is going to be secured better. The tensioner is off that’s why I am asking about removing chain links.OK... Lets take a deep breath here and think for a moment. Common sense says the pic you uploaded shows a very busy and troubling area. Everything is wrong! That brake is in the way and should be a different set-up. The muffler may need to be re-located and at least properly secured to the frame somewhere. The tensioner if used at all should be thought of as a guide not somthing putting tension on the chain. As said above it must be @ the bottom of the run not above. Remove the home made tensioner and wheel, that's just plain wrong. After undoing all that is there, take a wider pic showing the chain run from the engine on back to the wheel sprocket. Your issues (in my humble opinion) began when you mounted the engine. I have never built a Schwinn Stingray. Many others have. Do a search "Schwinn Stingray" Ideally some where is a posted pic of the Left side of bike. That will give you an idea. You need to do this safely. Don't get discouraged. Others have done this. Here is your link.
The brake is fine it’s not in the way it might be the angle of the picture but I haven’t had a problem with the brake only the pad which hit the chain but I trimmed a bit off to make it go smooth.OK... Lets take a deep breath here and think for a moment. Common sense says the pic you uploaded shows a very busy and troubling area. Everything is wrong! That brake is in the way and should be a different set-up. The muffler may need to be re-located and at least properly secured to the frame somewhere. The tensioner if used at all should be thought of as a guide not somthing putting tension on the chain. As said above it must be @ the bottom of the run not above. Remove the home made tensioner and wheel, that's just plain wrong. After undoing all that is there, take a wider pic showing the chain run from the engine on back to the wheel sprocket. Your issues (in my humble opinion) began when you mounted the engine. I have never built a Schwinn Stingray. Many others have. Do a search "Schwinn Stingray" Ideally some where is a posted pic of the Left side of bike. That will give you an idea. You need to do this safely. Don't get discouraged. Others have done this. Here is your link.
That is possible. You can try the following to alter a chain length if the chain remover doesn't work:
1. Remove the cassette and any screws that are holding the derailleur in place.
2. Remove the two bolts that hold the lower bracket on.
3. Separate the lower bracket from the upper bracket.
4. Remove the old chain by unbuckling each link, then pulling it off.
5. Install the new chain by buckling each link, then tighten the bolts to secure it in place.
