Oh my bad man I didn't even know what cc this is everyone says they aren't actually what they are like the 80s ain't 80s. But ya my bad mine is a 66ccThat doesn't look like a 49cc engine, it is kinda off topic but if the o.p. doesn't mind its OK.
Actually Skyhawk 48CC 2-stroke engines that are legal here in AZ.The OP also started this thread way back in 2009!!!! (back when you could actually still find real 49cc engines).
A 26T back wheel sprocket?she did 45 MPH with the stock pipe without the pipe cap cover and a 26 tooth on 26 in .
You have a low bar for "doing good" if you think having to replace your rings every ~600 miles or so is Doing Good.I dunno for my main mode of transport daily after over 15 months and like a 1000 mi. 3 sets of piston rings in I think I'm doing good.
Good to hear ;-}Nah I replace rings in specific as preventive maintenance and their cheap. I learned that as an an aircraft mech.
No low bar here.
This green bike is a perfect bike. I want it. If only they could be silent. They are illegal in Australia. Which is absolutely ridiculous considering the size of our continent and the distances we need to travel. Anyway nice bike! Love the built in tank and the jack shaft the gear system the wheels all of it. If it was mine I would probably have taller handle bars because I'm getting a bit older and comfort is starting to out way cool. LOLA 26T back wheel sprocket?
That is 1/2 the teeth as the stock sprocket, do you have to pedal most of the time?
You must really go through clutch pads too if you don't.
If you want usability of the pedals and speed go with a JackShaft Shifter conversion.
Once you 'get' the shifting you wonder why you ever rode without using bike gears with the engine.
That was a popular build for me but I usually used 66cc SkyHawk engines, or 49cc HS 144f-1g 4-stroke engines with a Skyhawk 4G or my 10G long shaft like this.
Legal, easy to ride, it will jump off the line and do 40mph all day, but capable of faster (45-50mph) with minimal maintenance required.
Gears change everything if you want to fast.
Thanks for the Kudos Matt.This green bike is a perfect bike. I want it. If only they could be silent. They are illegal in Australia. Which is absolutely ridiculous considering the size of our continent and the distances we need to travel. Anyway nice bike!
If you have a combustion engine you are going to have noise.We can make them silent with acoustic feedback, but I think it requires too much energy to neutralize the noise.
Sprocket size?
