Lack of power/bursts of power
D.Knight
82
CA
And if you notice, since the arrow faces the exhaust port, the gouging occurs only where the cylinder blew up
Actually I'm wrong, unless I had the piston backwards. If I had the piston orientated right, the blowout would be on the opposite side of gouged area of the piston. But I pulled both pins out of their homes and they were seated properly
Greg58
5,363
2,590
Newnan,Georgia
The marks or symbols on the top of pistons mean little to nothing more than manufacturing identifications, always install the piston with the ring gaps toward the intake.
  • Like
Reactions: D.Knight
KCvale
3,966
57
48
Phoenix,AZ
You don't line up ring gaps for heavens sake!
I put one ring gap to the left of the ports, the other to the right of ports.
There is nothing for them to hit that way, and the ring gaps are separated.
crassius
4,032
158
USA
wondering if factory screw ups include putting in a second clip by mistake - or maybe dropping one in motor and not getting it out
never seen a motor with clips that don't match
D.Knight
82
CA
Well I didn't find a clip in there, just the expected large shard of aluminum
D.Knight
82
CA
It may be just a piece of metal that was the same size as a clip that started the problem.
Sure was. You can see the area below the port blew out and caused the piece resting on top in the pic to do whatever it wanted inside the motor.
crassius
4,032
158
USA
not sure, but that looks like a bowl vent which would be open - take bowl off and stick a wire thru to see
D.Knight
82
CA
I just feel like if it was a vent it would have some kind of filter to prevent crap from making its way down into the bowl
D.Knight
82
CA
Yea this carb is a pos or something because I can't even go over 20 and it 4 strokes hard core. I'm using the gt80 jug that has the intake ported down the base and I put a 7/16 window in the piston. Not to mention, full throttle with clutch engaged is super choppy and all over the place, and it can't idle without throttle
Hoofbeats64
41
51
Minnesota
If I am at the hardware store, what plug do you buy for a 49 cc motor? I think I did something dumb... When my bike was grounded, I hung it upside down not thinking that this would probably foul the plug... I did wipe it off, however now that I am running again, it is really jumpy starting up. Lacking confidence with the chain being jumpy... wondering if the engine is doing that...
Greg58
5,363
2,590
Newnan,Georgia
When you say 49cc I think of a four stroke, if its a 2-stroke a B6HS NGK is probably the most popular. Most of the big auto parts stores here in my area carry that plug.
