My engine idles fine both after starting and when fully warmed up. However I have noticed that after using the throttle wide open (be it going fast or ascending a hill), if I pull in the clutch, the engine will idle very fast (to the point where I have to fiddle with the idle screw to slow it down). After a while of putting around at a slow speed I will then have to set the idle screw back to what it was originally.
Is this a carb thing where maybe the carb barrel is sticking to the side walls after wide open throttle or is this just a typical carburetor side effect?
