ezrider
Haven't had much luck yet with these tips:
# 1. How to Adjust Clutch if signs of slipping or squealing is encountered:
A) Disengage clutch by pulling handle bar clutch lever inward and lock into catch lock.
B) Remove right side engine clutch cover and remove small locking screw on center *Clutch Adjust
Nut.
C) Pull clutch arm on left rear engine inward. Back off *Clutch Adjust Nut ¼ turn counterclockwise.
D) Release handlebar clutch lever and check for slight 1/16” free-play on engine clutch arm.
E)Readjust *Clutch Adjust Nut as required to get required 1/6” clutch arm free play.
F) Tighten *Clutch Adjust Nut on clutch plate clockwise until just snug.
G) Then re-install small locking screw in outer edge of *Clutch Adjust Nut .
H) Good idea to place a small gob of grease at gear mesh area. Use grease sparingly! Then replace
cover.
I) Squirt light grade oil down clutch cable sheathing to reduce friction and make for easy lever pull.
Cutch Cover removed: Clutch Adjust Nut and Lock screw
______________________
Adjusting the clutch:
1. Adjust clutch cable so there is only a little bit of slack in the inner wire when the hand lever is released all the way out.
2. Remove gear case cover from right side of engine.
3. Remove lock screw from clutch outer plate. It's the little screw that fits into the notches on the edge of the center nut (called a flower nut).
4. Squeeze in clutch hand lever until it touches the hand grip. Hold it in with the lock button or some tape or a piece of wire, zip-ty, ect.
5. While pushing in on the outer clutch plate with one hand, tighten the flower nut until snug, just using your fingertips. Do not use pliers, ect.
6. Unscrew flower nut 1/2 to 1 turn out, aligning a notch on the flower nut with the hole in the outer clutch plate that the lock screw goes into.
7. Install lock screw but don't tighten it just yet.
8. Remove tape or wire from hand lever and let it release all the way out.
9. Tighten lock screw for flower nut.
10. Adjust clutch cable if necessary to give just a little free play to the inner cable when the hand lever is all the way out. You should be able to wiggle the clutch release arm a little.
11. Install gear case cover and test ride. Every clutch is a little different.
You may have to fine tune the adjustment of the flower nut by a few notches.
Anyone else have any other better ideas tips or suggestions ? Continually adjusting the cable, flower nut, lock screw without any effect it starting to get a bit frustrating.
Nut.
cover.
