Clutch Slipping
Okay, got the gear puller. Now the keys are on the shaft. So it seems that I will have to pull the LARGE gear first to get a look at it. Do I have to pull the smaller sprocket assembly on the other side...to get the larger gear out first ?
nope, each end will come off by itself (a 4.5mm allen wrench dropped thru chain on drive sprocket can keep shaft from turning while you work)
Well, just discovered sometin: Apparently, there is some kind of concave indentation on the tip of the bucking bar. A Bikeberry vid suggests it might be the issue. Problem is, that although the bucking bar came out....the ball bearing didn't. So to be on the safe side, I'll order both of these parts. In the meantime, I'll try and get hold of a steel rod...and cut it with those dimensions.
Some Tube vids say that this kind of bucking bar indentation wear is fairly common....and the source of engagement problems. Hope the replacement part works, cuz I really loathe having to take out the clutch shaft assembly...as would anyone else with an engine of only a few hundred miles usage.
I suspect you are getting way off the beam here - except for one bucking bar that shattered like glass (due to bad heat treat or something), they are too simple to fail some are long, some short, but all seem to work just fine once everything is together and adjusted.
Is the tiny ball bearing, or so called: 'Clutch Actuator Bearing' suppose to come out along with the Bucking Bar ? And if not......then WHY ??
it gets stuck in old grease sometimes - usually comes out by sticking a rotor magnet on end of bar, but I sometimes have to stick a tiny jeweler's screwdriver in there to clean all around the ball before putting bar & magnet in ti pull it out
Can't seem to screw in the gear puller onto to the large clutch bevel gear. What am I doing wrong here ?
it has VERY fine threads - clean threads on both clutch and tool well and take out inner tool bolt so it doesn't hit bottom before you're ready
I often turn it backwards in place a bit to be sure it is properly aligned before trying to thread it in.
I've always used the blower hooked to my air compressor --- it's always came out that way. Just be sure to hold your hand over the opening so the ball doesn't shoot across the garage!
