I love the weight. Better handling, stability and especially not so many problems with wind as before.
The main reason is, in most states it would be illegal to ride on the street as a motor bicycle.Been looking around on the site for a while and haven't spotted a complete 212cc build, i mean you would almost expect one on a stingray for a cruiser, why don't people put these engines on i mean they are what , 120 bucks at harbor frieght? seems like a steal to me so whats the hold up? Don't they push you at over 50 mph?
My HF 212cc hits 9,600rpm......any questions? It also has over 20hp!I have the HF 212 on a go kart. It's a monster. Thing can hit 7k rpms if you pull the governor and stuff. Careful putting that on a bike.
yeah I have a motor like that on my mini bike alky fed ,and I couldn't imagine putting that on a bicycle lolMy HF 212cc hits 9,600rpm......any questions? It also has over 20hp!
hahah.. (cough cough) I haven't laugh-coughed this hard in a long time!I'm planning out several 212cc predator builds, but instead of investing in strong frames which are very hard to find, I will be reinforcing the mounting areas and the stays.
Every bike will have a jackshaft, and will be registered and street legal.
All will cost a total of around $3000, plus insurance, registration, and tags
you can reinforce as much as you want. the frame will break at the border of the reinforcement then. you dont seem to understand how much vibration a 1cyl 212cc engine creates. people here including me are trying to stop you from wasting your money and probably injure yourself of someone else. i have actually built a 212cc bike and i spent nearly3k in that ****. if i would have known that before i wouldnt have done it. the engine is not good for bikes. even in gokarts its not that great.I'm sure you know what is a part of motorcycle or car engine mounts? Rocker joints are essential in absorbing those vibes. Those are going to be part of the reinforcements. Just small pieces of rubber between the engine and the mount to allow a very small amount of movement.the frame will be thickened at each mounting point by 1/4 inch and each reinforcement will be 3 inches long. I'm using my basic knowledge of how cars engines work to reduce vibrations to build these safely. I will not spare anything however to have the reinforcements professionally welded. The 3000 is to cover the cost of licensing, original inspections, registration, and insurance. The bike itself will cost me around 800, insurance will cost around 1500, registration is 60, inspections are about 40, and vehicle sales and manufacturing licensing will run me around 400, likely more. So to be able to turn some kind of profit, I have to sell at 3000 for some, higher for others. I am also a bicycle mechanic, and even riding some very weak frames to damn near the breaking point, have never had one break. Steel is the best way to go, even in weaker frames. Stronger frames are simply thicker. The stays need to be reinforced so they don't bend laterally from the torque. The mounting points need to be thickened and rocker joints added to the mounts so the frame doesn't torque out of shape. Even with a 66cc on my current bike, I know my rims need to be relaced with 12ga spokes. So, anyone got any other points they'd like to make?
I can guarantee you that even with all your "reinforcements" it will still not pass inspection. A bicycle frame will never meet DOT motorcycle safety standards, no matter what you do to it.I am able to get a quote from state Farm for a homemade motorcycle, and here in nevada, if it has an engine size larger than 50ccs, and can go faster than 35mph on flat ground with no more than 1 degree in any direction, plus has all required safety equipment, it is considered a motorcycle and must be licensed and registered as one. The frame with its reinforcements, once inspected, will pass, and will be licensed and registered. Just motorized bikes with 49cc engines have to be licensed and registered as mopeds for antitheft purposes. You did make a very valid point however necromancer. I did do my research before I even received the engine.
It will break if there isn't anything there to absorb any of the vibrations. That's where rocker joints come in. Between the engine and mount will be a 1/8 in rubber disk around each bolt. Between the mount and reinforced frame will be a rubber strip. That's the vibration reduction you need. The mount is probably about 1 inch wide, so 3 inches of reinforcing material will suffice. I will ride each and every build 100 miles at current speed limits both on the freeway and public streets, just to ensure that none of the joints bend or break. Have any of you who have built a 212 actually used rocker joints? Or any kind of rubber padding to reduce vibrations?you can reinforce as much as you want. the frame will break at the border of the reinforcement then. you dont seem to understand how much vibration a 1cyl 212cc engine creates. people here including me are trying to stop you from wasting your money and probably injure yourself of someone else. i have actually built a 212cc bike and i spent nearly3k in that ****. if i would have known that before i wouldnt have done it. the engine is not good for bikes. even in gokarts its not that great.
