THowell1975
I have searched this forum and haven't found an answer for this one. I have a problem with my magneto. It keeps burning out. The wires coming out the side of the plastic and are soldered to the base burn up. I've tried to resolder them and they may work for a couple of miles and then burn up again right at the solder joint. I've added enough solder on top of that and tried again and it ran, but burnt up again and now there's no more wire left to resolder. I've burnt up three of these the same way, so I don't think the problem really is the magneto anymore. It's like I'm getting too much voltage for the wire or something. Could this be the CDI? Any way to check?
I also bought one more magneto that doesn't have the white wire at all, just the blue and the black (and no pesky wires soldered to the base) and it worked for a few days and then it quit. It actually ohms out good between blue and black, but it won't make any spark anymore. I tried one of my "resoldered" ones after that one and it worked for a couple miles until that little wire burned up again and I couldn't resolder it anymore. I'm completely lost and out of magnetos and don't want to order any more until I figure out this issue. Any help would be appreciated. Thanks!
Oh yeah, on the ones with the white wire, it is cut off and heat shrinked, so no way is that shorting anything out. I'm thinking that if it fires up and works, everything is good in the circuit. But if it burns out after just a few miles, there must be something else. Or are these cheap little magneto coils THAT cheap that I need to keep a half dozen spares at all times?? My spark plug is the factory one and I assume it's good. Every time I add a new coil, I get good spark again. Until the coil burns up...
