Slowbuild79
How's it going ....would this work on the 79cc hf. I know the shaft size is different but could I just use a shaft reducer on it ? I would love to be able to just bump start it.
Been trying to get one of these clutches on the road. Since I run the GX200 with the cylinder vertical I had to make a custom bracket to support the cable pull system. In my application the bracket also acts as a front engine mount that ties the engine to the frame. Here is how it's looking.
Manual Clutch by Pat Dolan, on Flickr
The clutch primary sprocket will then feed back to my reduction drive system at the bottom bracket.
The secondary drive chain will then feed back to a Strumey Archer S1C heavy duty coaster brake hub with prototype sprocket adapter. I will now have a free left side handlebar for the clutch lever.
Prototype by Pat Dolan, on Flickr
!! SEXY !!Im assuming it would also work sitting on the bike cranking the pedals, old school styleie?
Some very good information on here. I've been looking at this clutch for a little while and now I think I'm pretty well sold on it
Say I put this on my bike. I've got a slightly built 212. I will have to fab my own lever lock correct? Otherwise it will always be engaged?
I like the idea of this so I can rev the engine with out the rear wheel going 40mph
