thingswithwelding
Will a bully clutch fit on a 79cc Predator with a jackshaft plate? Has anybody seen this setup? Ive never seen a Bully clutch in person and wonder if they are "wider" or just look wider? Thanks.
Thingswithwelding, I just went down and measured my Willard clutch against the Bully clutch I have and the Willard is 2-1/4 inches tall and the Bully is 2-5/8" tall. I didn't check the width but they aren't too far apart. I can check the width if you like.
Steve.
The disk clutch you are looking @ must be the one from Sportsman Flyer, it was designed to work with your engine, you may have to add a few washers on the shaft to space it out, included with the clutch.
Here's the Bully measurements.
Inside the clutch that sits on the crank shaft 2-5/16" long.
Bell diameter is 4"
Distance from end of the clutch to the outside of the sprocket is 1/4"
I haven't used the Willard clutch yet but I wouldn't recommend it. They are metal to metal and I don't see that lasting to long. It was just something to use to judge distances until I found a clutch that I wanted. The better shoe type clutches often require adjusting (replacing) the shoes and springs until you find a set that works.
You can buy a box of different spring weights and shoes and then it's a matter of replacing them until you get what you want. Ask the supplier of Bully clutches if it will work on your motor. I bought mine from Pat at Sportsman Flyer.
It sounds like you are getting clutch chatter as you pull away. That is where the shoes grab the bell and then let go and grab it again. The shoes hold tight once you are going fast enough. That is one of the benefits of the plated clutch. When it makes contact it doesn't chatter unless the plate is worn out or oily.
Hope this helps with your decision and if you need more information please ask. I posted photos of my Bully clutch on my thread Indian Tadpole. Silver bear started it so it's under his name. Click on the link and it will take you to my Photobucket account where the photos are stored.
It's in the Motorized Tandems, Trikes and Recumbent Bikes section.
Steve.
You should have jumped in Reno. It tells me if someone posted on it. Certainly glad I could help you. The thread is so old it has whiskers.
If you need anything else about the clutch let me know. I think it will make your riding a real pleasure.
Steve.
Sweet looking bike. If it was me I would pull the pedal shaft out of the bearing holders and then gently tap the bearing holders out of the bottom bracket from the opposite side using a length of wooden dowel and a hammer so you don't mess up the bearings.
Make sure you hit the bearing holders and not the bearings. If you go around it gently and from side to side so it comes out evenly and doesn't twist in the bottom bracket you should be OK.
I'd make sure to tell the powder coater not to get powder inside the bottom bracket. The bearings went into my bottom bracket tightly and if there was powder coating in there they never would have fit until I ground it out.
Bully presets the clutch to engage at 1,800 rpm and then tests it to make sure it does. All you have to do is install it. I would imagine that Cheetah does the same thing but I went with Bully because Pat sells them so I know they are good and builders like Culver City Classics and Norm at Venice Bikes who builds top of the line bikes use them.
Steve.
The Bully clutch uses #35 chain. That is the same style of sprocket that I'm going to use. The Bully clutch comes with a 12 tooth standard and you can order an 11 tooth sprocket but it's $4 and change more. Depending on what you have on the clutch now they have higher tooth counts.
I was wondering if you had made the frame yourself. Pretty good to get it right free handing it. I would think that a frame jig would pay for it's self on the first build.
Steve.
Steve.
I wouldn't worry about using #35 chain. When I was looking around the internet I came across a go kart site and they were discussing the best chain to use. One guy pretty much ended the discussion when he said that his 18 hp engines used #35 chain to power his cart and he'd used it for years. He included a photo of the wall of trophies and a bunch on the floor.
I've heard that KTM chain is the best and I think it was the KTM Gold that came already stetched.
t
Steve.
