My bike wouild run like crap to and I found out it was the brass piece the float slides on
I would check to see if it treaded in place
No offence but I don't like the idea of buying studs from a company that tries to charge $16 for low grade studs ? How do I know these "grade 5" bolts are really grade 5 quality.Yes you can buy higher grade studs. Or you can buy a complete hardware kit from SBP which includes upgraded studs.
Yah I see now it was a kit I was looking at but the bolts in the pic don't look to hot either..You can see a slight curve to them..They shouldn't have a curve. The grade 5 quality kit. How much stronger are they then I'm guessing the grade 8 quality I have.First of all we are talking about engine mounting studs, correct? Our kits are $9.95. For ALL the hardware. And these are not "low grade". We buy the hardware from quality companies and we look at the certifications.
Now our cylinder stud kits are $15.95, but these are a different part and are grade 8 equivalent.
If you can source these to length with all the hardware for less, then go for it.
Also, just because a stud or bolt has a higher number does NOT mean it's a "better" fastener.
Trust me. There is No curve in those.......it's either a camera/photo or monitor effect.Yah I see now it was a kit I was looking at but the bolts in the pic don't look to hot either..You can see a slight curve to them..They shouldn't have a curve. The grade 5 quality kit. How much stronger are they then I'm guessing the grade 8 quality I have.
The kit
