maniac57
I run 40:1 right from the start, riding normally with no full throttle over 5 seconds or so or going above about 6k rpm for more than a few seconds the first tank, gradually holding it open longer second through 4th tanks.
On the first tank I make sure to do LOTS of full throttle pulls from fairly low speed, just little blips up and down through the rev range but not going all out.
I gradually hold it wide open a bit longer and higher up in the rev range 2nd thru 4th tanks, at which point you're good to go usually.
As the engine loosens up and seals, you will feel the difference in midrange torque.
Notice the nice even wear pattern on the ring faces and the minimal blow-by discoloration underneath the rings. This indicates a good even ring seal with little leakage or lost compression and good contact with the cylinder walls.
You can just barely see the ring at the top of the port and it has no more than 1/8th" or so of discoloration below the rings.
This is what a good seal looks like in a chinadoll.
This engine is on it's second tank using the above process.
Been doing all my two strokes this way for decades and it works great for me.
Your results may vary.
