briggs carbs are meant for constant speed use and the NT is a good upgrade to improve throttle response.
Nothing WRONG with the briggs carbs, but the NT is easier to tune and keep clean.
The small bore is not an issue as the briggs carb has about the same size venturi.
I'm considering changing the carb on my Tecumseh powered snow blower to a spare NT carb I have. The stock carb is bogging down enough to be almost unusable as it is. I'll run more gas additive carb cleaner through it to see if it will run better, as I'f rather not fool with taking things apart in sub zero weather, but if that doesn't work I think I'd like to try the NT just to see how it goes.
SB
It looks like your pedal crank is geared kinda high, maybe 500rpm when your motor is turning 3000rpm. Maybe I am reading your tooth count wrong on that one picture.
How about showing the rest of the mini bike..................Curt
KOOL bike,i like it, thank god for fences,hide our goodies.
Yep cold down there also,it got up to about 19 today was shoveling some snow and saw a bike go by,see one just about every day.................Curt
